I used to have CUE on one laptop and VDJ on another - Now I have put both on one laptop. How do I use Same playlist and my song database for both programs?
geposted Sat 27 Oct 12 @ 11:03 pm
If you like to have VirtualDJ database and playlist to be the same with your Numark Cue or vice versa, assuming you're on PC:
goto Documents > Numark Cue folder > copy both Playlists folder and VirtualDJ Database v6 xml file > open VirtualDJ folder > paste > overwrite
The above will replace the VirtualDJ playlist and database and become identical to Numark Cue. You can do it the other way around if you want VDJ over Cue.
geposted Sun 28 Oct 12 @ 5:09 am
Thanks DJRANES - but my playlist folders- in both the CUE and Virtual DJ folders are empty - is that normal?
geposted Mon 29 Oct 12 @ 1:44 pm
