HI ALL NEW TO THIS IM LOOKING FOR SOME HELP,I WONT TO LINK MY DECKS AND MIXER TO VDJ BUT NOT SURE WHAT I HAVE TO DO,I HAVE
X1 BEHRINGER DJX900 USB MIXER (USB INFO BUILT-IN USB INTERFACE FOR RECORDING AND PLAYBACK)
X2 STANTON C.324 CD DECKS
X1 NUMARK DJIO
X1 LAPTOP WITH VDJ
ALL I WONT TO DO IS LINK MY SETUP WITH VDJ DO I HAVE TO HAVE USB DECKS ORE IS THERE A WAY AROUND IT,THANKS
X1 NUMARK DJIO
X1 LAPTOP WITH VDJ
geposted Sun 28 Oct 12 @ 5:01 am
Hey
first of all please don't write your text LIKE THIS. It seems you are screaming ;-)
your Setup would work with timecode and VDJ PRO FULL (because the players doesn't have MIDI ), but with your soundcard this doesn't work, because you only have 2 outputs an one input. Timecode requires a soundcart with 2 in- and 2 outputs....
just buy a 2 in- and 2 Out soundcard and VDJ...then it will work :-)
then connect the players with the soundcart Ins and the soundcard outs with your mixer. Then you only have to take the timecode signal (https://virtualdj.com/products/timecode/cd.html) on a CD and put it in the players.
greets from bavaria
chrisXD
greets from bavaria
chrisXD
geposted Sun 28 Oct 12 @ 6:09 am
@cool chrisXD
some think like this Behringer UCA202 U-Control Ultra low-latency 2 In/2 Out USB/Audio Interface
geposted Sun 28 Oct 12 @ 6:51 am
What Chris should have said is two stereo ins and two stereo outs.
Think about it, you have two decks and each one is stereo.
geposted Sun 28 Oct 12 @ 11:05 am
oh sry^^ yes he is right...i forgot the stereo
EDIT: i would not buy a cheap soundcard for timecode ! i had some very bad problems with cheap ones
geposted Sun 28 Oct 12 @ 11:17 am
Native Instruments Komplete Audio 6
2x Stereo in
2x Stereo out
24-Bit/96 kHz
should work fine...;-)
2x Stereo in
2x Stereo out
24-Bit/96 kHz
geposted Sun 28 Oct 12 @ 6:17 pm
geposted Mon 29 Oct 12 @ 10:40 am
