pioneer ddj-sx is out now and vestax vci380 been out awhile, just wondering if the vdj dev team ever going to map
a controller like that to vdj8 to be able to slice beats on fly and be able to adjust effects volume and parameters sensativity by amount of pressure applied to pad. ? do we have an vci380 owner that has this features mapped or tried to map.
thank you for your input in advanced
geposted Sun 04 Nov 12 @ 6:18 am
I´ve ordered DDJ-SX last week. I will inform you when i have it at home, than i try to mapp all VDJ avilable functions.
Regards Tomas.
Regards Tomas.
geposted Sun 04 Nov 12 @ 7:31 am
i would be very interested in this and i would also like to know if you can mix outside the software while using VDJ like you can with the MC6000
geposted Sun 04 Nov 12 @ 1:29 pm
Mapping a button with velocity, could be possible with ver 7 already, but dont have such a unit in my hands to try.
In theory, the button should give 2 kind of info in the Miditrace. One that will work like a button (on-off note), and another value that will behave like a slider (depending on the velocity)
In the def file you should have both defined, and in the mapper, the button could be e.g. sampler x play_stop and the slider could be sampler x volume.
geposted Sun 04 Nov 12 @ 1:57 pm
Strtch107 good ? I love the int mix mode of mc600 dont know if another controller
Has that feature. My friend got vci380 it only runs on pc mode
Meaning mixer controls software so u cant lower gain independent from software
Djdad i wish i had knowledge of mapping and making definition files ill be in dev team lol
Just wishing for xmas a mapping that does what vci380 does with itch but in vdj with my own effects
geposted Sun 04 Nov 12 @ 2:23 pm
The pads of the VCI-380 use MIDI notes with velocity. This isn't currently supported in VirtualDJ v7.2 but could be possible in a future version.
Pads that send MIDI CC's for their velocity could be supported in the current version if mapped appropriately, but the VCI-380 doesn't work that way.
Beat slicing would only be possible with a new native built-in effect that's capable of doing this and can be controlled via MIDI/mapping. It might also be possible using an existing user-made effect, but a native mapping can only be mapped by default to native functions.
geposted Mon 05 Nov 12 @ 9:57 am
you unfortunately can't map velocity sensitive buttons in my experience... you can however trick VDJ into thinking the velocity sensitive buttons is a potentiometer "knob/slider" and you can map them easily enough.
param_greater 50% effect 'effect_name' slider 1 & effect 'effect_name' active on : effect 'effect_name' active off
the red parts can be changed depending on what you want the button to do.
geposted Mon 05 Nov 12 @ 11:16 am
i confirm that the pads that send CC can be mapped like SLIDER for example:
<slider cc="0x21" name="PROG3_PAD1CC" deck="2"/>
then for example you can map the sampler with velocity:
sampler 1 volume & sampler 1 play_stop
i'm working on a mapper for the Akay LPD8 that use pad with velocity.
It will be online soon
geposted Mon 05 Nov 12 @ 2:26 pm
please if any one creates a slicer in a skin so upload it to meadiafire.com
geposted Sat 29 Dec 12 @ 6:59 am
Or you could just register your software here and then you could download it directly from here........
geposted Sat 29 Dec 12 @ 7:08 am
Nobody will do that. Illegal 3rd party sharing of VirtualDJ add-ons is not permitted in the VirtualDJ forums.
If you like VirtualDJ, please support the software and its future development by purchasing it: https://virtualdj.com/products/comparison.html
Once purchased and registered, you can then download any add-ons that your license entitles you to legally for free.
geposted Sat 29 Dec 12 @ 1:57 pm
