I'm using the skin that's supposed to go with my controller, but wish that it has some other features. This may be a simple answer question, but can I use a skin that's for another controller with my controller? I'd like to try a few others to see if I can see all four wave forms at once, maybe it has more or less of something I need/don't need, but I don't know if it'll work with the controller I have.
geposted Mon 05 Nov 12 @ 12:22 pm
The skin has no effect on the functionality of your controller and vice-versa. You can use any skin of your own choice, even one that's made to look like another controller.
geposted Mon 05 Nov 12 @ 12:27 pm
you can use any skin with any controller.. The skin is just a visual representation of what the software is doing. Some find it easier to learn with a skin that looks like their controller, however I personally find them tacky LOL.
Check out Phantoms CDS4 and DJ Dad's 4 deck GROM if you want to move away from controller like skins.
geposted Mon 05 Nov 12 @ 12:28 pm
