Anyone know what a good starting mix deck is. My wife and I are looking at the Numark mix decks.. Any help appreciated.
geposted Sat 10 Nov 12 @ 11:51 pm
have a look in the hardware section under the products tab on here....
it all depends on what you want to do with it and what you want to spend. but i would say its better
to buy one with a built in sound card ;)
geposted Sun 11 Nov 12 @ 12:50 am
Thanks will do that.
Just gettin started but am keen to mix my own versions of songs. Have been told to go for Numark mixdeck or N4.
geposted Sun 11 Nov 12 @ 12:56 am
Don't start off small if this is something your thinking of commitment to! that's what I did I ended up wanting something more suitable for my needs and I ended buying a beginner controller which isn't a bad one the rmx but the 300 I spent on that could have gone to Use on something else. I ended up with the ns6 6 months later. Which I'm satisfied with it for now.
geposted Mon 12 Nov 12 @ 12:22 am
Cheers for the help guys looks like the Numark NS6 it is. Cant wait gettin itchy feet.
geposted Mon 12 Nov 12 @ 11:56 pm
