Topic: [NEW] VirtualDJ 7.3 - Page: 20
Hey Guys Little scenario i have. i have a macbook and i want to use my dj mixer to conrol vdj bu i do not want to setup turntables i just want to blend files with the crossfader any suggestions
Here's a few, start your own thread for starters........ but since your here you'll need another soundcard with at least 2 outputs so you can split the channels up and run those into your mixer. It's that easy .........
Good luck and be sure to register your software so time can stay up to date
love the update and omg the sound is crazy! but it seems to be pumping way too much in my opinion. the previous version seemed to have an overall cleaner sound. with that in mind, i tried messing with the equalizer but i don't notice it changing at all. can anyone help me get the sound down a bit so im not blowing my speakers or my eardrums at my gig tomorrow? lol seems like a gain problem but i don't want to loose full sound by turning each song down. please help
Anyone having issues with cue points not staying on point? They do not line up when I load a track. So every time I load a track, I have to re adjust the cue point to the left.
Yes!! I thought it had something to with variations of waveform/skin. I noticed they are slightly off the beat.
mapeamento para ddj sx em qual virtual tem
Sorry, this forum is for English language messages only.
Please either post your message again in English or use the appropriate language forum at the bottom of https://virtualdj.com/forums to post in your own language.
post removed and place in correct discussion thread
I'm a new user. Am using Behringer BCD3000 controller...Sound Driver keeps "stopping?" ...Sound will cut out and, decks will stop spinning. But VDJ says "still playing". I have to go to Sound config and reclick apply. Works fine for a while then same over and over...Can someone please help...Never had problem before new version.
ok gracias a esperar mientras con este es suficiente
Thanks for providing such a great information to us. As this post is very informative and use-full to us. So please be in touch with such valuable post to us.
Moderated. Contact details removed
Any further update on the release?
artoym2002 wrote :
FINALLY SC3900 AND VDJ WORKS PERFECT.http://youtu.be/-RQE5Vs1GNY CHECK THIS VIDEO.
this video is in spanish and being hispanic I can understand what he's saying and I am actually glad I took the time to look it this video. His settings were dead on and since we have exactly the same setup. I went through and changed everything to match his and it worked perfectly, the cues work, the scratching works...bye bye Serato.
and I have three things to see or staff note with windows 8:
1-when mouse on the wheel are nailed images
2-items can not be loaded from outside the program in, dragging the track
3-clickbank not walk gives error loading loops
Well gentlemen, and found another problem with Windows 8, registrytool before with Windows 7 in 59MB menfree marked me with itel HD3000, now branded with Windows 8 only 27mb, so save problem ...
is it coming out for the LE version as well? the improved sound quality is pretty necessary for me.
99%
