I rarely post...but wow!! The sound has improved a lot!! Sounds much fuller on club sound system.
geposted Mon 12 Nov 12 @ 12:08 am
:-D
geposted Mon 12 Nov 12 @ 12:55 am
I used it tonight. Flawless...
geposted Mon 12 Nov 12 @ 1:03 am
Thanks a lot VDJ Team! Hope to be able to test it on the following weeks...
Cheers, DJ Castol.
Cheers, DJ Castol.
geposted Mon 12 Nov 12 @ 1:12 am
SC3900 native support enabled?
geposted Mon 12 Nov 12 @ 1:25 am
will there be an update for ns7 start stop time knobs and control of the speed for the motorwheel? im waiting for that
geposted Mon 12 Nov 12 @ 1:29 am
Hells Yeah! Now I am more than happy to wait for VDJ8.. .Great work guys.
geposted Mon 12 Nov 12 @ 3:04 am
THNX, WILL ALSO B WAITIN 4 BETA THOUGH...
geposted Mon 12 Nov 12 @ 3:09 am
Wow!! crispy clean and punchy!!...confirmed!!....whew....
geposted Mon 12 Nov 12 @ 3:10 am
Great work !!!
geposted Mon 12 Nov 12 @ 3:30 am
From VirtualDJ history: 7.3 - fixed high CPU usage for colored scratchWave on near-silent parts
No, this bug is still present in VDJ 7.3.
More here: https://virtualdj.com/forums/170084/PC_Version_Technical_Support/Color_waveform_is_taking_too_much_CPU__even_without_play_.html
geposted Mon 12 Nov 12 @ 4:30 am
Thanks for the gain limiter and the sound is much fuller in VDJ 7.3,keep rocking.
geposted Mon 12 Nov 12 @ 5:03 am
I want to report .. there is an small amount of noise when using master tempo (advanced) function, on vdj with my NS6, the only way to get rid of that sound is placing the pitch on 0% or turning off the master tempo. By the way this is the first time i notice that.
I tried increasing the latency but the noise is still there so, i got back to the usual 256 samples on the NS6 panel.
geposted Mon 12 Nov 12 @ 5:37 am
Will the sound in 7.3 be better bij using my denon mc6000?
geposted Mon 12 Nov 12 @ 8:14 am
Awesome!!
I don't know if I need version 8 anymore with this update! hahaha LOL
MANY Thanks to you guys!
geposted Mon 12 Nov 12 @ 8:43 am
@edmulder absolutely. I know first hand. I was bold enough to try out the new verison last night. This is the best version ever... and it will get better.
I had a problem with the 6000 when fading out of songs. At a certain point it would cut out (before this new version).
Now when I fade, it is actually a fade. The music does not cut out anymore.
geposted Mon 12 Nov 12 @ 8:49 am
Yeah sound is official!!! I decided to download it on my PC as I wait for my mac to come back and if this old XP PC can handle 7.3, I can't wait to get this on my macbook! I'll try the timecodes later and hope you guys add that color coded feature where I can label my music in the next update, unless you already did and I missed it somehow ;)
geposted Mon 12 Nov 12 @ 8:56 am
tnx
geposted Mon 12 Nov 12 @ 9:30 am
Ok Dj Koz thanks! other people with denon mc60000 and version 7.3??
geposted Mon 12 Nov 12 @ 9:39 am
I dont prefer to open a new topic. I woul like to ask which freq will you be using with new Parametric Equalizer. I was complaining that i cant kill mids completely and my aswer would be Parametric Equalizer. Btw i use ddj-ergo controller.
geposted Mon 12 Nov 12 @ 9:41 am
