I have just noticed the sampler is not matching the tempo of the decks no matter how its set in 7.3 has anyone else found this?
geposted Thu 15 Nov 12 @ 3:32 pm
Well I use the same settings you posted and I don't have any problem. I tried it with beatlock off and it will go out of sync then but usually I jump bump the pitch bend and its back in sync.
Hows the grid of your tracks set?? I have noticed that if its not almost perfect things will muck up real quick.
geposted Thu 15 Nov 12 @ 11:47 pm
The grid is fine, never had a issue before. The sampler is not changing speed at all with 7.3 let alone being even close
geposted Fri 16 Nov 12 @ 3:12 pm
Earlier this doesn't happen to my set-up... Now it does (sampler won't sync with the decks) :(
geposted Thu 21 Feb 13 @ 9:55 pm
