Hi all, if somebody has asked this before if you could could direct me to the answer that would be great. I am looking for a skin which contains the time on the tracklisting as well as the bpm. Skins I have downloaded seem to have this function on them however they dont seem to appear on my download when I use them.
Also is it possible to get a skin where I can hover over the waveform to see at what time a break etc is at. ie. if I hover over the middle of a song the time will appear where the pointer is.
Thanks
Gary
Thanks
Gary
geposted Thu 15 Nov 12 @ 8:32 pm
What you ask is irrelevant to a skin. Those are features of the software.
About hovering the mouse and showing the time, this is not currently possible. You may ask that in the Wishes and New Features Forum to be included in future release.
About showing information in the tracklisting,do you mean the Playlist window ? You can show ay track information, by rightclicking to a header and select any of the fields to be showed.
geposted Fri 16 Nov 12 @ 3:55 am
That was a great help thanks.
I will post in the appropriate section for software.
Thanks again
Gary
Thanks again
Gary
geposted Fri 16 Nov 12 @ 10:53 am
