Hi to all........This is my first post.
I bought Virtual DJ a couple of weeks ago from DJ kit in Newbury, and have started to get to grips with it.
My question is this? Does anyone know if my logo can be inserted to run on VJDJ while I am playing a mix, I use this dj system especially for Karaoke and want to place my new business logo within it?
Someone out there will know Im sure? I did the obvious and searched the forums but to know avail.
Thanks for your help.
Jeff
MaxxTraxx Karaoke
Jeff
MaxxTraxx Karaoke
geposted Fri 16 Nov 12 @ 4:31 am
Try the free Firetext plugin, you can use an image or video to display your logo etc any size and anywhere on screen.
As your a pro user you can also get the free sms version to use at your shows as well.
Go to the Firetext thread in the plugin forums for more info.
geposted Fri 16 Nov 12 @ 4:37 am
Firetext eh? Many thanks for your very prompt reply.
Cool
Jeff
Cool
Jeff
geposted Fri 16 Nov 12 @ 4:39 am
also try the show logo plug-in in the download section under video effects, if its going to be a simple logo splashed on the screen. firetext is brilliant, but does cost a few shekels.
geposted Fri 16 Nov 12 @ 6:53 am
A few shekels... it's FREE, you can't get any cheaper than that!!!
Wild you need to check out the plugin... you get all of this for FREE in one plugin plus FREE SMS for Pro users.
Go to the thread for full details....
https://virtualdj.com/forums/116228/VirtualDJ_Plugins/__FireText_Plugins_-_www_firetext_com.html?page=24
FireText VirtualDJ Plugin v2.44
Features
+ Choice of vertical or horizontal scroller
+ Image slide show and timed sequence rotation with pause and play
+ Camera picture in picture control
+ Template save for later properties/position retrieval
+ Alpha blend of text and images
+ Control location maintaing aspect
+ ChromaKey advanced filter
+ FireText Virtual DJ Robot for sending Videos To Screen (great for for your own or bar moving logos, adverts etc)
Extras
+ Text To Screen sourced from FireText Administrator
+ Random & pause image rotation from FireText Administrator
+ AVI/MPG movies sourced from FireText Administrator
+ SWF Flash movies sourced from FireText Administrator
+ Twitter client for screen name replies shown as normal messages
Prerequisites
+ Windows XP/Vista/W7
+ DirectX fully updated
+ VirtualDJ registered version
Known issues
+ Happens to freeze on some systems when camera driver hooks camera device
+ Not compatible with FireText v1.6.x.x versions, please get v1.7.1.x
Fixes for v2.44
+ Removed FireText logo from camera capture
+ Microsoft DX update June2010
Fixes for v2.43
+ Text message removal after sent (one by one & clear all)
+ FireText v1.7.5.25 required
Fixes for v2.42.1
+ UAC DXClose()/DXOpen() fix for Vista & Win7
+ Image rotation from FireText performed in background thread
+ Template tab has deletion button and load on double-click
+ Virtual DJ 6.1 checkbox label fix
Enjoy...
Features
Extras
Prerequisites
Known issues
Fixes for v2.44
Fixes for v2.43
Fixes for v2.42.1
Enjoy...
geposted Fri 16 Nov 12 @ 7:15 am
backdrop , show logo, clipbank......
if you have some video software you can make your own bits
and run them in clipbank or in combo w/ other software
geposted Fri 16 Nov 12 @ 7:43 am
Clipbank is no good chuck, he needs to show file over music vids or karaoke files. As far as I can tell he prefers it to be a moving video file.
geposted Fri 16 Nov 12 @ 8:36 am
I agree with Tayla.
Firetext plugin will help you with your logo and placement of the logo, transparancy of the logo and even switching logos and or commercials.
That's the only plugin you need
(No I'm not working for this company and do not have any other connection with it. I just love to use this plugin with every possibility without the need to use multiple plugins to have the same outcome)
EDIT:
PS: When I do karaoke I also use a webcam to project the singer(s) in a upper corner on the same screen as the karaoke video (with Firetext plugin)
EDIT:
geposted Fri 16 Nov 12 @ 8:42 am
Hi all,
Thanks so much for answering.
I am after a simple splash screen which will stay on screen even when just music is being played. I'm not worried about while the karaoke is on. Because I use a DJ starcloth to hide my stands etc, people keep asking what my dj name is.
Jeff
Jeff
geposted Fri 16 Nov 12 @ 10:32 am
Let's not forget about the Pangolin plugins, both FREE as well........ 48 clips and free SMS, all integrated in the software.........
geposted Fri 16 Nov 12 @ 12:03 pm
Sounds like you just need the "slideshow" plugin. Make a jpg or bmp picture file with your logo on and open it using the slideshow plugin.
You can make the "slideshow" automatically activate when you're playing a music video by going to the "config" menu, then the "video" tab and ticking the box to the left of "use this plugin for audio only files", then select "Slideshow" (or whatever plugin you end up using) from the drop down list to the right.
Hope that helps.
Hope that helps.
geposted Fri 16 Nov 12 @ 12:11 pm
@tayla - been awhile since i read any of the FT threads and didnt know it was free for VDJ registered pro-users - boss just doesnt want it in his bars even though i've explained that there were ways to control the messages that got to the screens (there's more to it just not that i'd discuss public)
by all means knock yerself out if ya got the system to handle it!
geposted Fri 16 Nov 12 @ 4:11 pm
Hope that helps.
Hope that helps.
Where is this "slideshow" plugin I cannot find it anywhere on the site.
Question, can I use this plugin to just show 1 pic when I am playing audio files? What format can this plugin "slideshow" handle? Can it play a mp4 or avi as well?
thanks in advance
geposted Mon 31 Dec 12 @ 3:08 pm
