iv had this since as far back as 7.05b.
at first it would normally happen if i did a reboot of my pc, but now it seems to happen from a fresh start of the pc.
normaly if it happens i would reboot the pc and the problem would be gone.
but today i had to rebbot the pc 4 times before it solved the problem.
instead of the stars in the rating section of the browser i get this:
is this a known problem with the software or possibly my pc setup?
thanks for any help as its starting to wear on my nerves ;)
geposted Sat 17 Nov 12 @ 11:54 am
Which OS?
I posted a "helpful hint" a while ago about how to enable them in XP here but the method for Vista, Windows 7 or Windows 8 will be different.
They're a unicode font called Black Star apparently.
geposted Sat 17 Nov 12 @ 12:17 pm
im running windows 7
packard bell with core i3 and 3gb of ram...
so is this a known issue or something more to do with the computer??
geposted Sat 17 Nov 12 @ 12:44 pm
im not much good with fiddling with codes and stuff but the last post on this page looked intresting?
http://www.fileformat.info/info/unicode/char/2605/fontsupport.htm
geposted Sat 17 Nov 12 @ 12:50 pm
It means the font is missing. You can either change the skin or edit the skin to fix the problem
geposted Sat 17 Nov 12 @ 1:04 pm
So, is there any permanent fix to the Rating Stars, if not then the Development team needs to take a look at this issue.
I've windows 7 and the Stars get replaced by squares at random times. Even if I don't change skins, I could have the Stars show up correctly and then exit and launch VDJ and the squares would show up. Then 2 days later the Stars would show up again. I've had this issue since 7.0.1
geposted Thu 21 Feb 13 @ 4:25 pm
We are aware of this and will fix in a future release
geposted Thu 21 Feb 13 @ 6:53 pm
awesome :)
geposted Tue 26 Feb 13 @ 2:09 am
in vdj 7.4 ??? ;)
geposted Tue 26 Feb 13 @ 6:47 am
