I have a choice between the Numark Mixtrack Pro or the Reloop Beatmix. I think I may prefer the Mixtrack over the beatmix but my main decider is the software. I have notice that the Mixtrack Pro is not supplied with Virtual DJ LE in the UK anymore. I have Virtual DJ Home and have decided that I prefer it over the over options but is there anyway I can aquire a copy of Virtual DJ LE for the Mixtrack Pro because there is no download on the website? If not I will just get the Beatmix.
geposted Tue 20 Nov 12 @ 10:40 am
There's no way to get the LE version I'm afraid unless it's shipped with your controller INSIDE THE BOX. :)
geposted Tue 20 Nov 12 @ 10:46 am
Ok thank you:)
geposted Tue 20 Nov 12 @ 10:50 am
I will PM you some options Teddy.
geposted Tue 20 Nov 12 @ 11:21 am
I'm in a similar boat, except I was told mine came with VDJ LE in North America. Numark says this on the Mixtrack Pro page on Amazon, "Plus, Virtual DJ LE comes standard in North and South America and Native Instruments' Traktor LE is included in Europe and Asia. "When i received my mixtrack pro, it only came with Serato intro. I had used VDJ Free before this for a while so I'm much more used to that software and would much rather use that with my controller and buy Pro, opposed to using Serato. If there is any other options, i'd appreciate it.
Thanks
Thanks
geposted Tue 04 Dec 12 @ 7:18 pm
At Numark's discretion and availability they may grant you a LE license.
Fill out their Software Authorization form, and explain you need an LE license for your device. You will need your controller's serial number.
http://www.numark.com/virtualdjleupdate
geposted Thu 13 Dec 12 @ 1:59 pm
I purchased a mixtrack pro and it said that it comes with virtual dj le. Instead it came with serato software. I hate serato software, I cannot grasp it and I am so used to using virtual dj which I love it, but cannot afford to upgrade to professional for $299. Does anyone know any alternatives. Thanks.
geposted Tue 26 Feb 13 @ 3:36 pm
Try to contact support by raising a ticket...
geposted Tue 26 Feb 13 @ 5:12 pm
