So our school (really small) is having a winter casual dance and they were going to have an iPod playlist going. I was like uhhh that's lame and offered to DJ it for them to AT LEAST have something better than a damn playlist. Problem is i have never done this before and figured i could use this as a cool learning experience. (gotta love those, right?)
So you didn't REALLY need to know that but why not. So what i want to know is this: I have my laptop with the dj software and that's all i will be using along with a mouse, now i can patch my laptop into the school system through my audio export but im curious as to how i might be able to do that but also have headphones to use the CUE function of the software....? Any advice? :)
geposted Tue 20 Nov 12 @ 9:55 pm
Go out and by yourself a Griffen cable. It'll split your sound into a mono signal so you wont have a true stereo output but it'll do what you want. Good luck.
geposted Tue 20 Nov 12 @ 10:13 pm
Ok, so that would split it into right and left channels so then to hear the cue i would play it through (for example) the right channel, and then i can play the house music through the left channel?
geposted Tue 20 Nov 12 @ 10:57 pm
Yes sir. Here's a link, http://www.google.com/shopping/product/773148135957273714?hl=en&sugexp=les;&gs_nf=3&qe=Z3JpZmZlbiBkag&qesig=NwktlS8i-SQEkmvfW-MMqQ&pkc=AFgZ2tkTaODMux5EyPJrvuzYV1ulPS_XMrnJv1RiuQeTA_zGzBkMCvxkE4vsc0Ha8D4GbXPXuYLYoKyDjDDj3TD8l8QkhTeTkA&cp=10&gs_id=1f&xhr=t&q=griffin+dj+cable&pf=p&sclient=tablet-gws&oq=griffen+dj&gs_l=&pbx=1&bav=on.2,or.r_gc.r_pw.r_cp.&bpcl=38897761&biw=1024&bih=600&tch=1&ech=12&psi=CmKsUOKbHa-xygGmuoH4BA.1353474573717.1&sa=X&ei=HWKsUNKUBonKyQGuyoDQCw&sqi=2&ved=0CDYQzAM
geposted Tue 20 Nov 12 @ 11:08 pm
