Does anyone else have mapping issues with their ns6 units?
Everything seems fine on the left side, but buttons and knobs to do with FX selection and use on the right do nothing. I've tried to reset them but it still does nothing. When I look in the mapping window in config (I'm on mac btw), there seems to multiple entries for parameters like 'FX_SELECT_A' but only one for B. I'm thoroughly confused I must admit.
Can I load up the ns6 file again to see if that fixes it, I know I could on the past but since its natively supported now (at least that was my understsnfing) I'm not sure of that cause further issues.
I was also trying to map Shift + FX parameter to the filter but it just won't work. I can do it with FX Parameter know for deck 2/4 but then it just controls the filter for deck 1.
I am seemingly out of my depth here with mapping, it just seems to go terribly wrong.
Thanks for any help!'
Edit
Just noticed that the shift key does absolutely nothing too.
Can i reset the whole ns6 template to see if that fixes these bugs?
Edit
geposted Wed 21 Nov 12 @ 7:09 pm
Well i went ahead and reinstalled the mapping file from CStoll after guessing its the same ampping thats now included since 7.0.5 and everything went back to normal. No idea what threw it all out, i had never even changed a anything before it went weird.
The rest should be easy to figure out now that all buttons are actually working again.
geposted Wed 21 Nov 12 @ 9:36 pm
You probably have an outdated definition file in Documents\VirtualDJ\Devices folder.
Manually delete all NS6 files from there and from Documents\VirtualDJ\Mappers folder as well, and relaunch the software.
geposted Thu 22 Nov 12 @ 5:07 am
