Hi, first off i apologise in advance if i am in the wrong section, or if this question has been asked a million times! Its just i am so frustrated with it now, and ive searched everywhere trying to work this out...
I have a tibo dj pro 2000 mixing deck which came with a copy of virtual dj.. When i connect my laptop via the usb cable supplied i can mix from cd to pc, pc to cd etc and use the tibo mixing desk for the controls (crossfade etc)
But if i mix deck 1 and 2 together on virtual dj then i have to use the crossfader on the screen as the 1 on the desk only works 1 sided..(if that makes sense)?!
Like i say i am a complete newbie, im guessingfrom what ive read that maybe its to do with channels etc?!..
I also read something about that you can use double rca leads or splitters?.. Does this apply to what im trying to do?..
Does anybody even understand what im trying to get across?! lol...
Any help would be much appreciated. Thankyou in advance
geposted Fri 23 Nov 12 @ 3:35 pm
I think that USB cable connection is just for AUDIO and not MIDI.
You need MIDI hookup in order for you to control VDJ with the controller.
geposted Fri 23 Nov 12 @ 8:48 pm
