Hi
i have an old midi controler - sound card that i want to use in my old pc for live proadcasting
BCD 2000 Behringer
It has a faction talk over that doesent work.. but i dont care
I would like when i press continuously this button.. to fade the music that is playing -10db so i can speak from the microphone.. and when i releas the button the music will come to the right level..
but i dont have the skils tou syntax this script to add to midi datebase
so any help from the experience users?
thanks in advance
BCD 2000 Behringer
thanks in advance
geposted Mon 26 Nov 12 @ 4:11 am
you could try something like this if you want a momentary action that will lower the gain for up to 4 decks.
deck 1 set_gain -10 while_pressed & deck 2 set_gain -10 while_pressed & get_decks 4 ? deck 3 set_gain -10 while_pressed & deck 4 set_gain -10 while_pressed : nothing
geposted Mon 26 Nov 12 @ 4:36 am
Thanks man :)
I think that is what i am looking for :)
i will try it and will tell the results :)
geposted Mon 26 Nov 12 @ 4:55 am
Personally I would avoid to mess with the gains. I would just set the volumes to a low level.
geposted Mon 26 Nov 12 @ 5:21 am
Thanks both :)
geposted Tue 27 Nov 12 @ 1:29 am
