Found a weird bug. It seems xfader start responds differently when there is another track playing or not.
Situation no decks playing:
- Cue the deck you wish to xfader start on
- cross over: Deck starts from que point.
- cross back: Deck stops and goes back to que point
Situation other deck playing:
- cross over: Deck starts from START song instead of que point
I might be mistaking that this is default behavior, but I've never experienced it like this.
geposted Mon 26 Nov 12 @ 2:09 pm
That seems to be the default and normal behavior, yes.
What fader Start/Stops does is that it starts the deck from the Cue point (if exists), but if the deck is already playing it doesnt stop it but continues from where it was.
If you need to play-pause the decks when you use the crossfader, this behavior may be achieved with vdjscript actions.
geposted Mon 26 Nov 12 @ 2:39 pm
Nono, the OTHER deck is playing so lets say deck A and deck B is que-ed up and starting with the fader.
geposted Mon 26 Nov 12 @ 2:41 pm
The situation was that I wanted to switch very abruptly from playing deck A to a qued point in deck B. I did that before with fader start. So very surprised that deck B kept resetting itself to start.
geposted Mon 26 Nov 12 @ 2:44 pm
A different behavior can be achieved though if you disable the FaderStartStops setting from the Registry Tool.
In this case if you enable the FaderStart feature using these actions.. deck 1 fader_stop and deck 2 fader_start, it will not stop the deck when you crossfade from one deck to the other, but it will start the deck if its stopped.
geposted Mon 26 Nov 12 @ 2:45 pm
Mmm I think i'm still not making myself clear enough. Nothing was happening to deck A. Either it was playing or not playing.
So..
Without deck A playing:
- xfader from A to B -> B starting at the Cue point
With deck A playing:
- xfader from A to B -> B starting FROM START, NOT at Cue point
And I want B to start at a cue point of course.
geposted Mon 26 Nov 12 @ 2:50 pm
I dont think the behavior of Deck B is relative to the status of Deck A.
If Deck B is on Cue point and paused (stopped), then crossfading from Deck A to Deck B, the Deck B will start from the Cue point of course, no matter if deck A is playing or not.
But if the Deck B is not at Cue point it will start from the point it is . This of course will change if you crossfade back to Deck A, as the FaderStartStop feature forces the Deck B to go to the Cue point position
geposted Mon 26 Nov 12 @ 3:06 pm
That is what I suppose it would be doing yes... But it doesn't :S even if deck B is paused on a cue point, if deck A is playing it will ignore that and start from start. I was very surprised, have you tried? Can you reproduce this?
geposted Mon 26 Nov 12 @ 3:10 pm
No i cant reproduce that. Are you sure you have both decks with faderstart enabled ? A skin with some relative indicators would help of course. Try the VMS4.1 skin to make sure
https://virtualdj.com/addons/11940/American_Audio_VMS4_Pro.html
geposted Mon 26 Nov 12 @ 3:12 pm
I even mapped faderstart to my controller. I'll try to get a movie of it with a skin that shows!
geposted Mon 26 Nov 12 @ 3:14 pm
Ok... whatever I do, I just cannot reproduce this anymore :S Soo resting my case.. still... i wasnt crazy... was I?? No you Werent?? really?? Yes we all saw it!! Ok....
geposted Tue 27 Nov 12 @ 2:06 pm
