i have reloop 3 me and After I upgraded from 7.0.5 to 7.3 the Mapping gone crazy, now i went back to 7.0.5 And everything works fine as before, Please note this support team, Luckily I checked before I left for work...
geposted Mon 26 Nov 12 @ 10:27 pm
I suppose you are referring to Reloop DigitalJockey 3. With 7.05 were you using a custom mapper or maybe a definition file exists in Documents\VirtualDJ\Devices ?
Can you inform us about what functions were working and what were not ?
geposted Tue 27 Nov 12 @ 10:51 am
djdad wrote :
I suppose you are referring to Reloop DigitalJockey 3. With 7.05 were you using a custom mapper or maybe a definition file exists in Documents\VirtualDJ\Devices ? yes
the jogs does not respond at all, the play and the cue Button does not respond, and if i press play on the SW with the Mouse The music starts but then it stops if i touch one of the jogs...
geposted Tue 27 Nov 12 @ 8:05 pm
Same here custom mapping for Denon MC600 3124 went haywire. Basic control works but nonoe of the custom shortcuts
geposted Wed 28 Nov 12 @ 1:41 pm
Do you guys have any definition file in Documents\VirtualDJ\Devices folder ?
For the DigitalJockey 3, it appears that the jogwheels are set to a very high touch sensitive value which probably cause even music to stop. Is there a sensitive touch slider on the hardware ? Could you please read the manual of the unit and see if there is a way to adjust this ?\
Djsolo, can you type here a custom shortcut that doesnt work ?
geposted Wed 28 Nov 12 @ 2:10 pm
