Hi,
I've had some issues with my Numark Total Control, I ended up taking it apart and making a small adjustment to prevent the crossfader from reaching all the way to the right (100 %). In previous versions of V DJ (7.0), this didn't matter, solved a technical problem but making the program not behave any differently - but now I can hear a fraction of the left track playing through to the main out. Is there a way of mapping it differently in 7.3, so as to solve my little problem?
Kind regards,
Kind regards,
geposted Tue 27 Nov 12 @ 1:40 pm
You can try this but I don't know if it will work:
param_greater 95% ? crossfader 100% : crossfader
Another workaround may be:
param_multiply 1.1 & crossfader
geposted Tue 27 Nov 12 @ 1:44 pm
I have tried implementing both via VDJ Script, but to no avail. So I'm bumping this thread, in case anyone else has any idea that might work.
geposted Sun 09 Dec 12 @ 2:02 pm
Ok - I finally made it work. It was probably due to my lack of understanding of scripting, but now everything is fine. Thanks!
geposted Tue 25 Dec 12 @ 5:31 am
