I had it sounding good before but reinstalled VDJ. Now the scratch sound is warbly, not clean. I know its an easy fix. Just need to be pointed in the right direction. Thanks (sorry for double post.)
geposted Tue 27 Nov 12 @ 7:58 pm
are you running 7.3? cause a few others are having the same problem....
geposted Wed 28 Nov 12 @ 12:35 am
yes
geposted Wed 28 Nov 12 @ 12:42 am
I had previously asked about this also, someone mentioned it can be fixed in the registry. I don't scratch on the 6000 so its not an issue for me and im sure it will be addressed in 7.4 and up.
geposted Wed 28 Nov 12 @ 8:40 am
Here's the text from the other thread: "Try to raise the registry value JogScratchLatency, to 2048 or even 4096 and see if it helps"
Not had the chance to dig out the MC-6000 to test this, but then I don't scratch so haven't noticed this issue at all.
Keith
Keith
geposted Wed 28 Nov 12 @ 9:01 am
it's happening with the Pioneer Ergo also, also intermittent "Aqua Effect" , no big deal though,
geposted Wed 28 Nov 12 @ 10:24 am
thanks keith. that seems to have fixed it :)
geposted Wed 28 Nov 12 @ 11:21 am
Excellent, thanks for letting us know.
Keith
Keith
geposted Wed 28 Nov 12 @ 12:02 pm
