Hello,
I recently did a fresh install of OS X 10.6.8 and installed flip4mac / perian, and virtualdj 7.3.
Whenever playing video (vob/mpg/mp4/avi) it begins to horribly lag. If I pause the video, I can watch it catch up by a couple of seconds.
I'm running VGA out using an apple supplied video adapter to my SONY TV.
I have a 17" Macbook Pro Unibody 7.1 (i5 core, mid 2010 model. NVIDIA 330 external / 2nd GPU)
I let spotlight successfully index, and I am able to reproduce this error even after re-booting and clearing NVRAM/PRAM.
Immediately after I check the box to enable video to the external device, the kernel_task goes to about 100-200% of the processor, and virtualdj video lags horribly bad (including the skin being slow).
So I have a horrible kernel panic. I used to own a 15" MBP mid 2010 v6.1 (I think its 6.1) and it would run video with no problems...
I have been to the apple genius bar previously and was unable to reproduce the problem, and when they returned the computer it functioned flawlessly for a month or two.. but now we are back to square one, where I am able to easily reproduce the problem.
I will continue to troubleshoot and post information from the console if I find anything.
Thank you for your time.
Please help.
Please help.
geposted Fri 30 Nov 12 @ 7:09 am
Guess i have the same MBP then you and didn't notice this issue.
Have you enabled to use the higher class videocard only?
Do you use 1080p videos?
geposted Tue 04 Dec 12 @ 7:40 am
I use all 480 vob / mpeg 2.
I always enable the high performance video card in the energy saving part of system preferences.
The issue has been fixed. I ran Apple Hardware Test and it turned out to be a bad GPU temperature sensor triggering my kernel panics, plus the MBP 17" from Mid 2010 has a NVIDIA 330M video card that can be faulty in some MBP 17".
Anyways, that was a nightmare of an issue to troubleshoot, so if your kernel_task is soaring out of control causing your video to lag, and you've done a fresh install, CALL APPLE and run AHT (Apple Hardware Test) because something is probably wrong with your hardware.
Problem solved, the macbook runs great now with no problems.
geposted Tue 25 Dec 12 @ 9:13 am
