Would using an ns7 at home, allow for an easy transition to using full 12 inch turntables ? With the aim of being as versatile as possible, is the ns7 the best choice for this?
geposted Sat 01 Dec 12 @ 12:30 pm
It's kind of the same as DJing with 45 records on a turntable without a needle.
-David
DJ Kavika
-David
DJ Kavika
geposted Sat 01 Dec 12 @ 10:13 pm
The only thing that would be the same would be the vinyl feel. I don't think this should be considered a transitional tool. the NS7 has many modern tools like cue points and looping that are not found on a 1200. You could get used to using these features on a NS7 and be screwed without them on a 1200. If you plan on using the 1200s with a DVS system then it might not mater but if your going old school with vinyl records you will not have the luxury of having the features found on an NS7
geposted Sun 02 Dec 12 @ 12:44 am
Thanks for the replies
I plan on using DVS as a lot of clubs have them installed. For my home setup, it seems that NS7 would give me the best value for my dollar while keeping the skills needed for a DVS system
geposted Sun 02 Dec 12 @ 12:30 pm
