Forum: Old versions
Topic: VirtualDJ Pro Full quit unexpectedly
I was upgrading to 7.3 on one of my macs and I got "VirtualDJ Pro Full quit unexpectedly " message. What is the problem and how can I fix it??
geposted Sat 01 Dec 12 @ 6:14 pm
Hi, did you fix this? Im having same problem. Thanks
Well I was able to fix it on one MacBook but not the other. I spoke to technical support and told me to check permissions thru utility. I was able to fix it by replacing the Virtual DJ folder in Documents. Very weird.
I am having the same problem with my MacBook Pro, VirtualDJ Pro Full 7. What permissions do I check and change? Where in the utility? In the Security & Privacy? What Virtual DJ folder in Documents did you replace? How did you replace it? Sorry...not up on detailed troubleshooting and repair...need the instructions for dummies...thanks in advance.
This is the message I got from support...
Message: This happens because probably you have installed Virtualdj in one of the two hardisk , not in the internal harddisk
Please download this tool:
https://virtualdj.com/addons/2170/Registry_Tool.html
execute the registry tool, and tell me what's in the "RunFolder" and "HomeFolder" field
i had the same thing happen but i have very little time on a mbp. only happened once w/ no crash report.
On the Registry Tool menu. See the home folder field it has /users/michaelpowell/documents/virtualdj. Don't see any Runfolder field. This menu is asking to apply or refresh clearall or quit. FYI - under the Homefolder is the iTunesfolder, with /users/michaelpowell/music/itunes
I guess that registry tool update...worked. Was able to start Virtual DJ without the "A problem pro full quit unexpectedly" error coming up. Will see if it last. THANK YOU!!!!!!!!!
It only worked when I had an external hard drive attached.
No go. Virtual DJ starts up when I power up my Mac, however, once I close Virtual DJ down and then try to restart Virtual DJ, I get the same error message when I go back to restart Virtual DJ. I have to shutdown my entire MAC down and re-power back up to reload Virtual DJ. Been running Virtual DJ for over a year with the same MAC and exterior hard drive and have had no problem until recently. ????
Can anyone else confirm that it will only work when having an external hard drive already attached when starting up VDJ?
i also got this problem , i just reinstalled virtual dj on my mac than it works fine.
