Hello everybody,
I got a Numark Mixtrack Pro from sonicelectronix.com, it came with the Serato dj intro software.
Its there any way i can get the Virtual dj LE? I did contact sonicelectronix and they told me that they cant do anything about it.
I would like to buy the VIRTUAL DJ PRO FULL, but its really expensive and I know that i can get a discount if I own a Virtual Dj product but my mixer did not come with one.
Thanks
Thanks
geposted Mon 03 Dec 12 @ 3:55 pm
Unless the software came with the controller then there is no way to just get LE. You can purchase the software. It is definitely worth buying the Pro version. You just have to do your research before you buy like most do. I don't mean to sound harsh but that's the reality of it.
geposted Mon 03 Dec 12 @ 4:20 pm
Thanks for the answer DJ KOZ, yeah i know its worth it buying it. I guess i will have to save to do it maybe by the time I get the money VDJ8 would be out!!!
geposted Mon 03 Dec 12 @ 4:37 pm
