Hey guys, I downloaded the Faderstart plugin but it does not allow me too use the volume faders on decks 3&4 to start the trackbut works fine on decks 1&2. I was wondering is there anything I can do to get it to work with all 4 volume faders or is there a script I can put in and map a button. Thanks.
geposted Mon 03 Dec 12 @ 5:40 pm
The plugin was designed long time ago and definitely before VirtualDJ became a multideck software.
But there is no need to use that plugin as VirtualDJ has Fader Start implemented.
using deck x fader_start , you can enable/disable faderstart to any deck you wish. It should work fine with the volume faders, but for the crossfader, you may have to set the crossfade sides properly (which deck is left and whicj is right)
geposted Mon 03 Dec 12 @ 5:44 pm
Ok but how would I write the script for the volume fader I tried putting in faderstart and it stopped controlling the volume
geposted Mon 03 Dec 12 @ 5:59 pm
Ok i got it thanks a mill DjDad your the best!
geposted Mon 03 Dec 12 @ 6:31 pm
Is there a way to only have the Volume Faders and not the Crossfader operate the Fader Start. Right now they both operate it.
geposted Sun 30 Dec 12 @ 10:49 pm
