How can I add the above icon to my profile, I've done a search and it mentions generic VDJ LE icons, but not how to add specific ones.
Is there a 4.1 icon, where is it, how do I add it ?
If it's a stupid question, please feel free to delete the post!
Thanks
Thanks
geposted Thu 06 Dec 12 @ 7:13 am
You need to register the serial of the LE version that came with the controller and your icon will appear.
If you don't have the serial then it's not possible.
Keith
Keith
geposted Thu 06 Dec 12 @ 7:45 am
Registered the copy of Virtual DJ LE that came with the controller, all it's giving me in the Virtual DJ LE Icon not the controller icon.
Didn't know whether there was a separate bank of icons you could add to your profile ?
geposted Fri 07 Dec 12 @ 7:46 am
I think this has been covered before. Not all LE versions have a controller icon, some only have the box. It can't be changed I'm afraid....
Keith
Keith
geposted Fri 07 Dec 12 @ 7:51 am
Cheers Keith, thanks for your prompt reply.
geposted Fri 07 Dec 12 @ 8:02 am
