I have the following systems. One of them is a denon hc4500 and a pioneer djm3000 mixer and the other one is a denon hc4500 and mc6000. Which one would you guys prefer using a why? I want to sell one of them just don't which one? Any feed back will be appreciated.
geposted Sun 09 Dec 12 @ 11:46 pm
Which one do you not use the most? Which one do you not like? There's your answer.
geposted Mon 10 Dec 12 @ 12:26 am
I prefer Allen & Heath mixers, therefore you should buy a Xone:DB4 and use that.
geposted Mon 10 Dec 12 @ 3:15 am
Seems like a strange combination
geposted Mon 10 Dec 12 @ 2:08 pm
I use the 4500 as decks 3 and 4. That way I have four decks
geposted Mon 10 Dec 12 @ 3:58 pm
The MC-6000 supports 4 decks natively in Virtual DJ itself. No need for another controller.
Keith
Keith
geposted Mon 10 Dec 12 @ 4:10 pm
Hi,
I understand your combination... so far, maybe I would let the DJM300 out... and add a DJM-5000 or any rack mountable with the HC4500. You don't need it but is welcome to allow you control 3 and 4 deck inside VirtualDJ using the MC6000, so you can only use the MC6000 audio outs without using more than a usb cable to connect your HC4500.
HC4500 is great for this type of rack mount controllers. But If I would stay with only one, maybe I just would use the MC6000. Currently I have the 4500 and the MC6000, and others too, both are good for me, but I use to use more the mc6000 than the 4500 now.
geposted Tue 11 Dec 12 @ 12:14 pm
