Hey guys. i wanted to know how do I install QB Filter plugin into VDJ its a VST file, I downloaded the file but don't know how to actually get it to work inside of VDJ. If anyone can help it will be gratefully appreciated.
geposted Thu 13 Dec 12 @ 3:50 pm
Place the ".DLL" file into VDJ's sound effect folder. Then the next time you open VDJ it should be there ready to go.
Hope that helps
Huey
Hope that helps
Huey
geposted Thu 13 Dec 12 @ 4:41 pm
Yep that did it thanks Huey
geposted Fri 14 Dec 12 @ 12:51 am
No problem,
Enjoy......
Enjoy......
geposted Fri 14 Dec 12 @ 8:33 am
