Hi,
I am currently a VDJ LE Owner as it came with my VMS 4.1
If I pay the upgrade fee to pro can I have a copy on both my main system and my backup system which are both PC. Also if I switch to a Macbook Pro can I remove it from my backup PC and switch my old primary PC as a backup? Bottom line questions is can I have two copies installed and can one be a PC ver and one a mac ver?
geposted Thu 13 Dec 12 @ 4:31 pm
Yes you can, your allowed your main machine and a backup.
geposted Thu 13 Dec 12 @ 4:37 pm
.....as long as they're not both in use at the same time.
geposted Thu 13 Dec 12 @ 4:39 pm
Thought that's what "backup" meant............
geposted Thu 13 Dec 12 @ 4:43 pm
His bottom line question was "Can I have two copies installed", so it's worth reinforcing the point about only running one at a time.
Although he could run the LE version simultaneously, as that'd be on a different serial number, right?
geposted Fri 14 Dec 12 @ 5:22 am
Good question......... never thought about that one.
geposted Fri 14 Dec 12 @ 8:35 am
