When I'm mixing I use my hercules steel.
I also have a korg nano key which I have mapped for cue's and samples. this was all working fine, apart from one snag which was the sample volumes which i couldnt control without a slider/knob. So i bought an akai LPD8, as I needed a drum pad for FL studio, AND it has 8 assignable knobs.
I opened up VDJ, mapped the knobs to sample vol, and this worked fine....
Now I have a problem that when i Press one of the buttons on my control steel, It will for example, activate the effect mapped to it. but also play one of my samples..
The only thing I can think of is VDJ recognises the knobs/controls on the akai LPD8 as the same button on the control steel
HOWEVER. when i turn a knob for vol sample on the LPD8 it doesn't enable an effect
Sorry the post is long and iv tried to explain best I can!
geposted Fri 14 Dec 12 @ 12:34 pm
SOLVED!
The aksi lpd8 was on the same channelas the hercules steel, Iv changed the channels and no problems now
geposted Sun 16 Dec 12 @ 3:30 pm
