Hey everyone, i got a quick question hopefully someone can help me with. Okay so i am going to be setting up my first timecode vinyl setup. I have a stanton t62 and a stanton m201 mixer (i think thats what its called haha). Now my question is, for the sound card, since i am only going to be having one TT and the mixer, do i need a 4 in 4 out sound card? Im really trying to go somewhat cheap with this set up. I just wanna practice scratching. What would the best cheap sound card be? Thanks!
geposted Mon 17 Dec 12 @ 9:18 am
https://virtualdj.com/wiki/Timecode%20Requirements.html
As per the link, you will need an Asio compliant card. Please also note the home version of VirtualDJ will only work for 10 minutes as a demo. You need a registered version of Pro to use timecode for more than 10 minutes.
Keith
Keith
geposted Mon 17 Dec 12 @ 9:46 am
Thanks keith,
But just to be sure, I still need a 4x4 even if I'm only using one TT and a mixer? Rather than 2 TTs and a mixer?
Thanks again.
Thanks again.
geposted Mon 17 Dec 12 @ 9:52 am
You need 2 inputs (1 stereo) for each Timecode deck you need to use, so if you run a single timecode, just a stereo input will do the job.
(2inputs, 4outputs)
(2inputs, 4outputs)
geposted Mon 17 Dec 12 @ 10:06 am
Okay thanks alot. Now how does the mixer connect?
geposted Mon 17 Dec 12 @ 11:56 am
