I downloaded this midi mapping for The Novation Twitch: [REMOVED]
It looks awesome, unfortunately I can't managed to install it. I put the xml file in the Mappers folder on my harddrive, opened VDJ and went to Config/Mappers but the mapping isn't showing up. I may have to rename <mapper device="Twitch", I tried a few TWITCH, Twitch 1 etc but didn't help. I spent the whole evening trying to figurate out but failed :/
Any idea?
Thank you for any help.
Any idea?
geposted Tue 18 Dec 12 @ 6:41 pm
you need to make sure that the mapper is installed in the mapper folder and the definition is in the devices folder.
you can remove the sysexid or drivername field to make it respond to the controller regardless of device name, however this will provent you from using other MIDI devices at the same time and may cause you to hear MIDI notes from your sound card if its handles MIDI.
geposted Tue 18 Dec 12 @ 10:44 pm
@sostelvio
Please do not post links to external sites. The official mapper is available on this site for licensed users.
Please note you will need a licenced version of VirtualDJ pro full to be able to use the controller. Please support development by purchasing a licence.
Keith
Keith
geposted Wed 19 Dec 12 @ 3:24 am
