Numark DJ io has no driver for windows 8. Who does?
geposted Wed 19 Dec 12 @ 11:51 am
According to Numark support, the Windows 7 driver should work.
You don't always need to install a new driver after you've upgraded your OS.
geposted Wed 19 Dec 12 @ 12:25 pm
Well, it doesn't work.
geposted Sat 08 Feb 14 @ 2:55 am
Be more specific.
Does the driver install? Are you connecting the DJIO to a USB 3 port?
geposted Sat 08 Feb 14 @ 6:29 am
can you run software in windows 8 as compatibility mode?
are you using windows 8 or 8.1?
if so check out the threads on win 8.1
geposted Sat 08 Feb 14 @ 1:58 pm
