I have seen similar threads that have discussed problems regarding key lock....Here is my issue. I can have a track playing on deck 1 at say, 93
bpm and do a quick sync to bring a track on deck 2 at 99 bpm in line with deck 1 at 93 bpm for a quick transition...So both decks
are now at 93 bpm,....the second track comes in, 1st track I fades out....Now, when I go to hit the icon (I have it keyboard mapped) on
the side of the pitch slider to gradually bring track 2 back to its original pitch, I get a faint crackling, static sound until it reaches the
original pitch again of (in this instance 99 bpm)......Is this a hardware/PC issue, or VDJ issue that will be fixed with VDJ 8? (I'm
running Win. 7, 3.2 dual core AMD processor, Numark DJ/io soundcard, all my CPU use indicators are never peaking above 60% usage)
geposted Fri 21 Dec 12 @ 1:55 pm
Yeah also notice this, I think the closer you are to the original BPM the more possible crackling you get. Mainly in mid section, especially when there is only vocals or a single instrument.
geposted Fri 21 Dec 12 @ 2:45 pm
