Download --> HERE <--
My new skin inspired directly by previous Millenium_skin and influenced by the design Pioneer, it always exploits with 2 screens 1280x1024, what is almost necessary so there is of options and possibilities with Virtual DJ !
But this time I added a great deal of options and several exchangeable panels, according to needs.
LEFT SCREEN :
On the left screen we spend this time in 4 decks, with down the waveforms of every title on all the screen width, what allows a fast location of breaks or Cue points :
RIGHT SCREEN :
On the right screen we find the browser as well as a sampler independent from the Virtual DJ menu :
THE EXCHANGEABLE VIEWS :
On the left screen we can choose between the wide waveforms or the Browser. With this last choice the skin becomes independent and can be used on 1 only screen.
On the right screen 3 choices offer themselves to you:
A browser on all the page.
A browser reduces with the independent sampler.
An audio / video mixing desk (see above)
Full Browser :
Browser & independant Sampler :
THE EXCHANGEABLE PANELS :
On every deck we can change the display of a small zone in the middle. We can thus choose between :
¤ a mix panel
¤ a video panel
¤ an effects panel
¤ an option panel
¤ a titles information panel (tags)
¤ a scratching panel
UNSYNCHRONIZATION ALARMS :
A interesting feature: a visual alarm which flashes if the bpm of the decks 1 and 2 is not identical.
To what that can be of use while the values of BPM are just registered above ? And indeed it is very simple, when we quickly mix, when we chain fervently the titles and when we count on the automatic BPM to prop up the latter, he can arrive that the BPM does not synchronize!
Indeed when one work with more of 2 platinum, the new title in charge of is going to settle comfortably on the deck in "Master's degree". But he can arrive whether
it is the bad deck which is Master's degree!
With this alarm, a red frame will flash around the Sync button.
But so that it works, it will be necessary to install the little plug "WatchDog " joined. Think also of activating it in the VDJ options (Effect menu, tab "Other").
Another alarm of the same type is next to the pitch of 4 decks and indicates that this one stayed at 0. It means that the BPM did not synchronized (except in exceptional circumstances of a title of which the BPM is exactly just with the pitch 0)
DIVERSE OPTIONS :
A click on the song title opens the window of the track options.
A click on the BPM opens the window of BPM adjustment.
Under the mixer we can show a beatkeeper on 4, 8 or 16 beats.
On the Effects panel, a right click on a button allows to choose the effect of this button.
LED light to indicate each limiter activation (each deck and master limiters)
IN THE COURSE OF IMPROVEMENT :
- The passage in functioning in 1 screen is going to be still improved.
geposted Sat 22 Dec 12 @ 4:58 pm
Skin Update :
- Fixed a bug in the display of interchangeable views on each deck.
- Small fixes graphics.
- Added a visual alarm synchronization between deck 1 and 2: now the waves bottom becomes red if the two decks are not sync.
in progress :
- New version "light" version of the same skin, also for two screens (mixer and video mixe are removed).
- Other version for 1 screen, for the moment without mixer.
in progress :
geposted Fri 25 Jan 13 @ 11:01 am
@Dodge57:
this skin looks perfect! i'd love to try it out, however i can't! i'm a new member and new members can't download skins (strange?!).
is there ANY way you could upload it to 4Shared or MediaFire and link it? i would be eternally grateful if you did.
thank you, sir!
thank you, sir!
geposted Wed 30 Jan 13 @ 5:21 pm
that is not possible, the only way to download it is on th official Virtual DJ website, so here.
The reason you can't download skin is that you hav'nt registered your version of Virtual DJ on the site !
geposted Wed 30 Jan 13 @ 5:53 pm
Very good Job Dodge :)
geposted Thu 31 Jan 13 @ 6:01 am
thanks ^^
geposted Thu 31 Jan 13 @ 6:01 pm
Nice
geposted Sat 02 Feb 13 @ 3:47 pm
new version "LIGHT" avable : http://fr.virtualdj.com/addons/15635/Black_Millenium_v2_LIGHT.html
Still working on 2 screens and this time with only 3 decks.
Mixer and video options are deleted.
All other options are available, including independent sampler, limiters indications, various alarms for sync or title end etc...
Ideal for small PC config or simply for those who do not need the other options !
A version 1 screen coming soon !!
geposted Sun 03 Feb 13 @ 5:34 pm
