I use the backspin effects all the time when i changing genre, tempo, etc.. and sometime forget to deactivate it, when I switch to the other song, most know the rest of the story. What script command must I use to automatically deactivate this effect. i tried "while_pressed" but that does not stop the song at the release of my key, the song will continue. I also try "holdin & down" and still didnt get the expected results. What I would like if possible is when i press my backspin key, the backspin will happen for a few seconds then stop the song & deactivate the effect. Thanks.
geposted Mon 24 Dec 12 @ 10:10 am
Config> Options> FX Reset on Load "enable"
This will clear all effects for the deck when a new track is loaded.
Keith
Keith
geposted Mon 24 Dec 12 @ 10:18 am
Had the same problem..easy quick fix...whichever key you most likely use after you've engaged your effects, just mapped that key to reset effects. If that key is already mapped put & . Hope that works
geposted Mon 24 Dec 12 @ 10:28 am
Keith
Keith
This would not work for me because the next track is already loaded. Thanks anyway.
Great suggestion kevilev, I will try that. Thanks yardy, big up !.
geposted Wed 26 Dec 12 @ 8:47 am
you could do something like this...
play ? effect 'brake' active on : effect 'brake' active off & play
It will make it so when you press play from being paused or stopped it will automatically turn off the brake effect.. You should also have a look at chackl's great new brake as it sound's better than djcels original and actually stops the track in the right position. The original version is purely a sound effect but chackl's is a transport effect as well as a sound effect.
geposted Wed 26 Dec 12 @ 12:45 pm
