Forum: VirtualDJ Plugins
Topic: selectRVT: Random Video Transition
Hi all,
I've just released selectRVT - a Virtual DJ effect that allows you to enable/disable video transitions from those used for random selection.
It's also an 'other' plugin so won't impact on other video effects and can't be accidentally disabled!
https://virtualdj.com/addons/15534/selectRVT.html
A VDJScript command can also be mapped to re-choose a transition at random:
set $selectrvt_random 1
A brief video demonstration can be found here: http://youtu.be/7zYuYLLDFVE
Regards,
Scott
geposted Thu 27 Dec 12 @ 12:37 pm
Scott, thanks for the new plugin. You are very invaluable to the VDJ community. I want to let you know that I appreciate all the work that you do and I hope all the other DJs on VDJ also feel the same way. We should all donate money to you because of the time it's takes to make all these plugins. Thank you again.
Super Slick Scott!!
Thank You!!
Sorry for putting it here, but this idea is similar to what I've been looking for with the ClipBank plugin;
1. Would like to know if the clipbank randomizer can be made to run the clips sequentially.
2. If an option or a Plugin... can be made to assign a list of different clipbanks to run sequentially from a list,.... for example,
provide a box where the name of the clipbank can be filled in by the user or a tick box to pick from a list of available ClipBanks where the following can be made;
A. ClipBank1.dll
B. ClipBank2.dll
C. ClipBank3.dll
D. ClipBank4.dll
E. ClipBank5.dll
F. ClipBank6.dll
G.ClipBank7.dll
....and so on, and also be able to set a duration for the overal time this plugin/option will change between each ClipBank by the user..
The idea here is to automate this process that can only be done manually.
Thanks...
Perfect work ! Thank you very very much !!!
one man cheering Squad coming up!!!...Nice one SB!!
Any way to make this work with Automix Scott??
Very Nice
Maybe a Mac version in the near future??
This is AWESOME! WOW. Was getting murdered in a Serato vs Virtual debate last night. Thanks Scott!
Awesome thanks!! How did I miss this one??
can you run sonique in video effects on a apple mac
No, Sonique plugins only exist for PC (They were originally created for the PC media player Sonique.)
