I just upgraded to the latest VDJ on my Macbook Pro running OS 10.7.5.
When I started VDJ after inputting my Software Key the loading splash screen comes up and looks like it's working and then when it gets to Initializing Graphic Engine.... it seems to freeze... all the while my external hdd is active like VDJ is reading it.
I've tried Force Close and restart.... same thing
I've tried Force Close and re-install.... same thing
I've also tried Force Close, Delete VDJ and it's components then re-install... same thing.
It's been stuck now on this screen since I started this post... so it's just hung, what do I do?
geposted Fri 28 Dec 12 @ 9:17 am
Ah-Ha.... it was the PC version of the VDJ Data Base file.... when I copied my PC library to my Mac formated external hard drive.... I copied that file as well..... Once I deleted that file VDJ booted properly.
geposted Fri 28 Dec 12 @ 9:55 am
