Hello I would like to know what would you recommend me for my karaoke set up.
I would be using my mp3+g files on virtual dj and a pair of shure sm58, should I get a normal FX mixer or a dedicate karaoke mixer. Any suggestions? I would like to be able to adjust the mics echo.
Thanks!!!
Thanks!!!
geposted Sun 30 Dec 12 @ 1:50 pm
It might help if you give an idea of how much money you want to spend.
geposted Sun 30 Dec 12 @ 4:58 pm
Well I don't want to spend a lot of money, my budget would be around $300.00.
Thanks
Thanks
geposted Sun 30 Dec 12 @ 7:40 pm
For karaoke purposes you dont need more than this Behringer XENYX 1202FX around $100 us. I've been in the karaoke business for over 30 years now and this is the simplest it gets and does the job. Just keep the preamps for the mic lower than 12 o clock and the mics sound good. Use the last stereo channel in for your controller/soundcard or laptop.
geposted Sun 30 Dec 12 @ 7:41 pm
Thanks for the advice on the Behringer!!!
geposted Sun 30 Dec 12 @ 8:40 pm
You will also need to upgrade to the full VirtualDJ Professional to be able to play karaoke full-screen. Your LE version that you have now is free limited software and is limited to a small video window only, which may be too small for your singers to read. Your LE version should entitle you to an upgrade discount: https://virtualdj.com/buy/
geposted Mon 31 Dec 12 @ 4:13 am
Just look at that cheap unit, it has metal jack inputs, not those plastic ones that Denon and Pioneer use! if you can do it on a cheap unit like this then why are Denon and Pioneer being so tight?
geposted Mon 31 Dec 12 @ 5:09 am
I've heard people say good things about the studiomaster C3X.
http://www.studiomaster.com/products/C3&C3X.htm
Very compact if space is an issue, and it has built in reverb, etc.
geposted Tue 01 Jan 13 @ 12:10 pm
Thanks for the info i did not know this. Ill try to upgrade soon.
geposted Wed 02 Jan 13 @ 6:28 pm
Lol, that would of been me.
The C3X has been the best investment I ever made!
geposted Thu 03 Jan 13 @ 5:09 pm
