im running two numark icdxs and a hercules rmx its all set up correctly i can do a mix and record it etc...... and it plays back perfectly , my problem is when i try to video a mix the video is fine but i have no audio playback if i use windows movie maker or virtualdub could it be because im trying to do it through the pc headset or should i just be doing it with the amp and speakers on and using the hercules as the main soundccard? thank you for any help
geposted Sun 30 Dec 12 @ 8:39 pm
