Hello guys, I just bought me a Dj Console rmx2 from hercules. I installed the cd, I got the software. But when I was ready to play, it won't play any sound.. I actually don't know how to connect my speakers to the controller.
I will link wich speakers I have.
http://www.google.be/imgres?um=1&hl=nl&sa=N&tbo=d&biw=863&bih=810&tbm=isch&tbnid=EKI63JtwACSwKM:&imgrefurl=http://jctronics.com/jct/scripts/prodView.asp%3Fidproduct%3D73&docid=akOSnhS-g7Ru1M&imgurl=http://jctronics.com/jct/ProdImages/SP-ITR3300-L.jpg&w=450&h=397&ei=bJvkUNGMD5K1hAeZ6IGIBQ&zoom=1&iact=hc&vpx=4&vpy=123&dur=1357&hovh=211&hovw=240&tx=139&ty=109&sig=106037745246026944104&page=1&tbnh=148&tbnw=168&start=0&ndsp=24&ved=1t:429,r:0,s:0,i:87
Any advice?
Thanks,
Any advice?
Thanks,
geposted Wed 02 Jan 13 @ 2:42 pm
Simply connect the green connector from your speakers to Output 1-2 on the back of the Mk2, and your headphones to the front connector.
geposted Thu 03 Jan 13 @ 6:01 am
I will try this, mate. Thank you for responding and trying to help me. But the green cable, there is one in my pc, and one in the woofer. My speakers are at the moment connected to my woofer, so yeah, we'll see what happen.
Thank you ,
Thank you ,
geposted Thu 03 Jan 13 @ 12:13 pm
Nah it doesn't work..
geposted Thu 03 Jan 13 @ 2:16 pm
My mistake. I misread DJ Console MK2 instead of Rmx2
So referring to the using manual:
http://support.creative.com/manuals/download.aspx?nDownloadId=2421&prodName=Quick%20Start%20Guide%20for%20the%20I-Trigue%202.1%203300
The cable #11 has one end going to the sub (Audio Input), and the other end, the one you normally connect to your PC, needs to be connected to Output 1-2 (Boot Out 1-2) of the Rmx2. For this, you will certainly need an adapter, or a replacement mini-jack to RCA cable:
DO NOT connect the speakers directly to the Rmx2. There are meant to be connected to the subwoofer to get to necessary power.
As for the audio configuration of VDJ, it should be as follow:
geposted Thu 03 Jan 13 @ 2:24 pm
I put a photo on the other forum, mate.
geposted Thu 03 Jan 13 @ 3:14 pm
TS115A 800w do I need an amp to play for a party of 200. Thanks for your response
geposted Thu 03 Jul 14 @ 1:56 am
The TS115A speakers are active units - meaning that the amps are built in.
geposted Thu 03 Jul 14 @ 3:46 am
