Hi,
Can i use external soundcards with Virtual Dj Basic?
Example:
I have a Numark dj io (external soundcard with asio drivers), a analog mixer and a laptop with Virtual dj Basic installed. Does this work or are the external soundcards also seen as MIDI?
Example:
geposted Thu 03 Jan 13 @ 2:25 pm
Take a read here:
https://virtualdj.com/wiki/Will%20VirtualDJ%20work%20with%20my%20mixer.html
If you have a legal version you should register you're serial number so you won't lose it and be able to download the latest version.
https://virtualdj.com/users/edit.html
geposted Thu 03 Jan 13 @ 7:48 pm
Basic version ( https://virtualdj.com/products/basic.html ) supports USB multi-channel Sound Cards, so your Numark DJio will work fine with your analogue mixer.
geposted Thu 03 Jan 13 @ 11:39 pm
Thank you for the answer, very helpfull.
I was looking for a very mobile setup with the proper software. This seems to fit perfect :)
geposted Fri 04 Jan 13 @ 12:44 pm
