Hi, I'm new to digital djing and hoping to get some advice on compatibility of different controllers.
I have a Reloop BeatMix which comes with Virtual DJ Reloop edition. It emulates the layout of the BeatMix which helps when mixing.
I have the opportunity to borrow a Reloop Terminal Mix 4 for a little while, which I understand also works with Virtual DJ. Can I use the Terminal Mix with my exisiting software and if so, how do I get to control 4 decks?
(I'm using version 7.1 downloaded from the Reloop website)
many thanks :)
many thanks :)
geposted Fri 04 Jan 13 @ 8:19 am
LE versions are always specific to the controller they ship with, so no - your Beatmix version won't work with the Terminal Mix.
What you can do though (to try the controller out) is to run the trial of VDJ Pro Full.
geposted Fri 04 Jan 13 @ 9:41 am
