Hi!
Im a newbe to all what dj is all about, i have Numark dmc-2 + CM200USB mixer.
Im thinking about buying a Virtual prodact, which one ?
One other thing, i have a lot of samplings and drumloops in my computer, can i use them in this software and can the software automaticly change bpm of the drumloop if i want to play it in background ?
How many samplings can i play at the same time ?
Thanks in advance!
/Fredde
Thanks in advance!
/Fredde
geposted Tue 08 Jan 13 @ 1:00 pm
If you want to use the DMC2 with VDJ, you must buy the Full Pro version. Other versions do not support controllers.
You can play 12 samples at one time using the sampler.
Unfortunately the sampler will not sync the tempo of drumloops unless they have been played in a deck first and recorded into the sample slot.
geposted Tue 08 Jan 13 @ 1:07 pm
But if i lets say make a drumloop with dmc2 that goes in 130 bpm, can i then record it and save it to Virtual DJ sampling list and then use it later in a song that goes 140 BPM and Virtual DJ automaticly change the BPM to 140 ?
/fredde
/fredde
geposted Tue 08 Jan 13 @ 2:05 pm
Yes that's the way it's designed to work.
step 1 - load a song to a deck
step 2 - loop a section of that song
step 3 - record the loop into a sampler slot
step 4 - save the loop as a sample
Then the saved sample should play in time to tracks loaded in the decks (if you have the correct options selected in the sampler).
Hopefully VDJ 8 will have a better sampler!
geposted Tue 08 Jan 13 @ 3:37 pm
Ok thanks :-)
Can this be tried in the demo version or do i have to buy the full version to try how this is working?
So when is the next version 8 planned to come ?
I only have Cue Le now, will that give me any discount if i buy full version of VDJ ?
Thanx in advance!
/fredde
Thanx in advance!
/fredde
geposted Wed 09 Jan 13 @ 12:12 am
You can try it out in VirtualDJ Home FREE, but your DMC-2 will only work for 10 minutes at a time.
Please see our FAQ pages:
https://virtualdj.com/wiki/When%20will%20the%20next%20version%20of%20VirtualDJ%20be%20released.html
Yes, there should be a discount available to upgrade. Simply go to https://virtualdj.com/buy/ and enter your CueLE serial number in the box provided to find out how much.
geposted Wed 09 Jan 13 @ 12:20 pm
If i want an external sampler that works with vdj and can change bpm of the samplers, will that be a smart thing to buy or ?
If so, which sampler would be good to buy? I want to be able to change tempo of the drumloops and so on of course.
Or is it better to sellmy equipment and try to find something better with built in sampler, is there any good ?
/fredde
/fredde
geposted Sun 13 Jan 13 @ 8:18 am
How about the Roland SP-404SX?
geposted Sun 13 Jan 13 @ 8:36 am
But can i on that change bpm on thoose drumloops that i have in my computer to match the songs played in vdj?
or can i make a loop in vdj and transfer it to 404 and then change bpm?
Hmmmmm, this will be to complicated for me i think, at least it sounds very complicated :-)
only what i want is to get samplers and drumloops and get them match to 100% with the songs in vdj :-)
geposted Sun 13 Jan 13 @ 11:36 am
Yes you can change the BPM of the samples on the SP404. It has a tap button and you can also set the BPM with a dial.
You can transfer samples from a computer onto the SP404 or you can record from your mixer.
Another option is to use Ableton Live software for samples, and sync Live to VDJ using ReWire.
If you do this, the CBG (beat grid) tempo information from tracks playing in VDJ is sent to the slave software (e.g. Ableton Live).
Read about ReWire
Read about ReWire
geposted Sun 13 Jan 13 @ 11:50 am
This sounds even more complicated :-)
Let see, maybe its easier to handle all drumloops and samplers direct from vdj.
geposted Tue 15 Jan 13 @ 2:08 am
Hi again, why cant i register my copy of Numark Cue LE, it says that the serial already has been register !?!?!
Can i have 2 logins here ?
How do i do ?
/Fredde
How do i do ?
/Fredde
geposted Mon 21 Jan 13 @ 1:26 pm
Please see https://virtualdj.com/wiki/Serial%20Transfer.html
If you need any further assistance, please contact support: https://virtualdj.com/contact/
geposted Mon 21 Jan 13 @ 1:49 pm
Everything is fine :-)
Thanx
Thanx
geposted Tue 22 Jan 13 @ 7:52 am
Hi again :-)
What about mapping, how is that works and do i need to download it for my DMC2 z
Im a little affraid that my equipment (cm200usb + numark dmc2) will be to old for VDJ soon, will this work with VDJ 8 or is it time for me to upgrade?
geposted Fri 25 Jan 13 @ 2:11 pm
VDJ8 should pretty much be backward compatible with older equipment so no worries there.
Keith
Keith
geposted Fri 25 Jan 13 @ 2:18 pm
