Topic: Pioneer ddj wego button on controller stop working
Hi ive recently bought the pioneer ddj wego and all ive had is problems, but my final problem is i will be mixing and all of a sudden most of the buttons on the controller stop working e.g. TUrntables, hot cues/samplers, cross fader, play pause . The master volume and headphone cue button work and the volume controls at the top. When this occurs all buttons work on virtual dj, and the wego recognises this.
My cpu when there is no music is creeping into red and my processor is 2.00 Ghz could this be then problem help!!!
geposted Tue 08 Jan 13 @ 3:04 pm
Does is sometimes quit working with a pop through the speakers?
If so it could be you are shorting the device causing a spike(eg when you
exit a car and touch the door - static electricity). This is what
I suspect as I have the same issue and its regular. There is no Earth clip on the back
in the old days you could attach a wire and earth the stereo or other device.
Just a guess.
on another website: suggested replacing the USB cable with your printer cable, and I've played it for 30 minutes, problem solved.
I just swapped the USB cable of the DDJ-WeGo (Pioneer supplied with the product) with my HP Printer USB cable.
Prior to that the DDJ-WeGo controls (onscreen Virtual DJ) would freeze after 5+ minutes, around 8+ times an hour requiring a PC restart every time. Major hassle. I simply switched the two cables - the printer still works and the DDJ-WeGo has been perfect.
Good day, guys... I need program Virtual DJ wego pro. Where I can tj download them? If you can to post LINK for this program, o'kay?
The USB cable may be faulty. Purchasing a high quality USB cable as a replacement is recommended.
The Pioneer WeGo comes with VirtualDJ LE (Limited Edition) included, not Pro.
If you wish to upgrade to the full VirtualDJ Pro at a discount, please go to: https://virtualdj.com/buy/
To download the latest VirtualDJ LE, please register your VirtualDJ LE serial number to your account and then go to the Download Center to download it.
If you have lost the serial number for VirtualDJ LE, then please see: https://virtualdj.com/forums/151663/General_Discussion/Lost_Serials_-_VirtualDJ_LE_or_any_other_version.html
NOTE: Please do not ask users to send you links to download software to which you are not currently entitled or you account will be locked. If you like VirtualDJ, then please support the software by purchasing it (Especially if you are a working DJ and you are making money as a result of using it at your gigs.)
Buenas noches acabo de comprarme la DJ wego
y cuando inicio el VDJ que viene con el equipo me solicita actualizarlo por una versión nueva,
cuando doy el OK me solicita el N° de Licencia para poder registrarla,
ese numero donde se encuentra para poder cargarlo
Desde ya Muchas gracias,
Saludos
