Hi i recently bought the Numark Mix track and now have a problem,
I installed virtual DJ and i have the audio working brilliantly but when I plug the controller into my pc then load up the software all that happens is my deck stays lit up, and when i try pressing play on the deck or use the cross-fader nothing happens on my virtual DJ. (Latest software and drivers), (all audio setup correctly) Please Help! :)
geposted Fri 11 Jan 13 @ 4:26 pm
Any ideas?
geposted Sat 12 Jan 13 @ 6:06 am
What version of VDJ are you using? There's nothing registered on your profile and although you say "latest software" you don't specify WHICH version it is you're trying to use.
geposted Sat 12 Jan 13 @ 6:56 am
Hi 7.0.3 and i also have 7.0.5
geposted Sun 13 Jan 13 @ 6:35 am
Please update your version. 7.0.5 is not the latest available version.
Greets, Heiko
Greets, Heiko
geposted Sun 13 Jan 13 @ 6:53 am
Is that VDJ Home, VDJ Broadcaster, VDJ Pro Basic, VDJ Pro Full or an LE version?
If it's an LE version, which version (i.e. which controller was it supplied with)?
It is for some versions. It depends which version he's using.
geposted Sun 13 Jan 13 @ 6:56 am
Pro :)
geposted Sun 13 Jan 13 @ 7:22 am
Please register your Pro serial number in your profile, download the latest version from this website and report back.
Regards
Keith
Regards
Keith
geposted Sun 13 Jan 13 @ 7:28 am
