Gadget Man,
I need your help por favor. I am trying to record music and mic at the same time, but am having no luck. I hear from Keith that you use the DN-MC6000 to broadcast and have no issues w/ your mic. I've tried the setting exactly as Keith posted them is the thread below, but it doesn't work for me. Any ideas?
From Keith:
"Found the original thread. Read my comments at the bottom of page 6 and see the screenshots on page 8.
https://virtualdj.com/forums/138914/Hardware_Technical_Support/The_Denon_DN_MC6000.html?page=6"
Here's my setup:
- MacBook Pro
- VDJ Pro (7)
- Denon MC-6000 controller
- Shure SM-58 Mic (connected to Denon MC-6000 - XLR Mic input)
My settings on top:
- Mic 1 "ON"
- "POST" is "ON"
Back of Mixer:
- "MAC"
- "INT MIX"
- "REC OUT/MIC"
Thanks,
-IM
From Keith:
Here's my setup:
- MacBook Pro
- VDJ Pro (7)
My settings on top:
- Mic 1 "ON"
- "POST" is "ON"
Back of Mixer:
- "MAC"
- "INT MIX"
- "REC OUT/MIC"
Thanks,
-IM
geposted Sat 12 Jan 13 @ 9:27 pm
I didn't realise you had a mac. This worked on Windows machines. The sound Config on a mac is completely different and that may be the issue.
Keith
Keith
geposted Sun 13 Jan 13 @ 3:14 am
I think you'd best ask Silvio over on www.denondjforums.com
geposted Sun 13 Jan 13 @ 6:16 am
I'll lock this one as Roy has responded in your other thread.
Keith
Keith
geposted Sun 13 Jan 13 @ 9:12 am
