Hello - How does one connect VDJ Pro with CDJ-900's and DJM-900 and be able to controller VDJ from the players and mixer?
Thank you for the help.
geposted Mon 14 Jan 13 @ 1:22 pm
There are two ways. Use the CDJs as USB MIDI controllers, or use a timecode signal.
geposted Mon 14 Jan 13 @ 1:57 pm
groovindj - Thank you for the reply. Are there any documentation on how to do either of those?
geposted Mon 14 Jan 13 @ 3:06 pm
The CDJ-900 manual has instructions on how to connect it to DJ software, but it's essentially the same method as connecting any
USB device - use a USB cable to connect the device to the computer.
The DJM900 manual has information on settings required for timecode. Again, use a USB cable to connect it to the computer.
geposted Mon 14 Jan 13 @ 4:31 pm
Anything that I need to download besides this?
geposted Mon 14 Jan 13 @ 4:51 pm
VDJ PRO
https://virtualdj.com/buy/
geposted Tue 15 Jan 13 @ 2:04 am
