Is it possible to save changes to a mapper if you alter some of the settings so that if you do an update on VDJ or re-install it you dont lose the customised settings.
The reason I ask is I have changed a few of the buttons in Phantoms DDJ-SX mapper and dont want to lose them if I need to re-install
geposted Tue 15 Jan 13 @ 3:58 pm
You can keep a backup of the mappers folder in the Documents\VirtualDJ folder. I keep a backup of the entire folder personally.
geposted Tue 15 Jan 13 @ 4:16 pm
Thanks will try that, I wasnt sure if you could simply rename a mapper and definition file
geposted Tue 15 Jan 13 @ 4:22 pm
