Hey,
I was using Virtual DJ Limited Edition, which came with my MIDI controller.
However my laptop has completely broken! I now have a new laptop but no Virtual DJ to use
Is there any way of getting a replacement copy of the program?
Who should I contact?
Thanks
Thanks
geposted Fri 18 Jan 13 @ 6:47 am
Reinstall it from the CD.
Alternatively enter your serial number in your forum profile, then you can download it (and any future updates).
geposted Fri 18 Jan 13 @ 6:50 am
As above. If you don't have the CD sleeve with the serial number you will have to contact the console manufacturer to retrieve the number.
https://virtualdj.com/forums/151663/General_Discussion/Lost_Serials_-_VirtualDJ_LE_or_any_other_version.html
Keith
Keith
geposted Fri 18 Jan 13 @ 7:17 am
